Einleitung
The back panel covers internal components. This guide will help remove it in order to access those components.
Was du brauchst
Use a Phillips head 000 screwdriver to remove the 4.0mm screw at the side opposite of the USB port.
Use a Phillips head 000 screwdriver to remove the three 4.0mm screws on the bottom of the camera.
Tilt up the LCD screen.
Use a Phillips head 000 screwdriver to remove the two coarse 4.0mm screws near the bottom of the camera.
