Zum Hauptinhalt wechseln
Sony Alpha NEX-C3 Control Wheel Replacement
Was du brauchst
  1. Sony Alpha NEX-C3 Control Wheel Replacement, Top Panel: Schritt 1, Bild 1 von 1
    • Turn the camera off by sliding the power switch.
  2. Sony Alpha NEX-C3 Control Wheel Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips head 000 screwdriver to remove the 4.0mm screw inside the USB port.
  3. Sony Alpha NEX-C3 Control Wheel Replacement: Schritt 3, Bild 1 von 1
    • Use a Phillips head 000 screwdriver to remove the one 4.0mm screw on the side opposite of the USB port near the shutter button.
  4. Sony Alpha NEX-C3 Control Wheel Replacement: Schritt 4, Bild 1 von 2 Sony Alpha NEX-C3 Control Wheel Replacement: Schritt 4, Bild 2 von 2
    • Open the flap at the top of the camera.
    • Use a Phillips head 000 screwdriver to remove the two 4.0mm screws inside.
  5. Sony Alpha NEX-C3 Control Wheel Replacement: Schritt 5, Bild 1 von 1
    • Gently lift off the top panel with your hands.
  6. Sony Alpha NEX-C3 Control Wheel Replacement, Back Panel: Schritt 6, Bild 1 von 1
    • Use a Phillips head 000 screwdriver to remove the 4.0mm screw at the side opposite of the USB port.
  7. Sony Alpha NEX-C3 Control Wheel Replacement: Schritt 7, Bild 1 von 2 Sony Alpha NEX-C3 Control Wheel Replacement: Schritt 7, Bild 2 von 2
    • Use a Phillips head 000 screwdriver to remove the three 4.0mm screws on the bottom of the camera.
  8. Sony Alpha NEX-C3 Control Wheel Replacement: Schritt 8, Bild 1 von 1
    • Tilt up the LCD screen.
    • Use a Phillips head 000 screwdriver to remove the two coarse 4.0mm screws near the bottom of the camera.
  9. Sony Alpha NEX-C3 Control Wheel Replacement: Schritt 9, Bild 1 von 1
    • Gently pry off the back panel, by wiggling it around the LCD screen.
  10. Sony Alpha NEX-C3 Control Wheel Replacement, Control Wheel: Schritt 10, Bild 1 von 2 Sony Alpha NEX-C3 Control Wheel Replacement, Control Wheel: Schritt 10, Bild 2 von 2
    • Grab the silver plate, and gently pry it up.
  11. Sony Alpha NEX-C3 Control Wheel Replacement: Schritt 11, Bild 1 von 2 Sony Alpha NEX-C3 Control Wheel Replacement: Schritt 11, Bild 2 von 2
    • Gently pinch blue ribbon cable, and pull it out of the port.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
UC Santa Barbara, Team S1-G1, Weedon Fall 2017 Mitglied von UC Santa Barbara, Team S1-G1, Weedon Fall 2017
UCSB-WEEDON-F17S1G1
3 Mitglieder
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 36
Insgesamt: 3,106
