Einleitung
The control wheel is used to navigate through pictures, and can wear down over time, and will need replacement.
Was du brauchst
Use a Phillips head 000 screwdriver to remove the 4.0mm screw inside the USB port.
Use a Phillips head 000 screwdriver to remove the one 4.0mm screw on the side opposite of the USB port near the shutter button.
Open the flap at the top of the camera.
Use a Phillips head 000 screwdriver to remove the two 4.0mm screws inside.
Use a Phillips head 000 screwdriver to remove the 4.0mm screw at the side opposite of the USB port.
Use a Phillips head 000 screwdriver to remove the three 4.0mm screws on the bottom of the camera.
Tilt up the LCD screen.
Use a Phillips head 000 screwdriver to remove the two coarse 4.0mm screws near the bottom of the camera.
Grab the silver plate, and gently pry it up.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
