Einleitung
The lens mount can wear over time and improper installation of the lens could break the inner plastic ring of the lens mount.
Was du brauchst
Use a Phillips head 000 screwdriver to remove the four 5.0mm screws on the E-mount.
Press on the lens mount button with one hand.
With the other hand, grab and gently wiggle off the E-mount metal ring until its free.
Remove the plastic ring located under the metal ring.
Fast fertig!
Abschluss
