Zum Hauptinhalt wechseln
Sony Alpha SLT-A55V Battery Replacement
Was du brauchst
  1. Sony Alpha SLT-A55V Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Locate the battery compartment on the bottom of the unit. Then, slide the latch down to open the cover.
  2. Sony Alpha SLT-A55V Battery Replacement: Schritt 2, Bild 1 von 1
    • Insert the new battery and close the compartment.
    • Most new lithium batteries are partially charged to improve shelf life. It is recommended to charge the battery after installation even if the indicator shows a full charge. Unlike nickel cadmium batteries, lithium batteries will provide better performance when charged to full capacity from a partial charge of 60%.
Abschluss
There you go, now you have a fully functional camera again. Do not forget to recharge the other battery to be prepared to repeat this guide.
IUPUI, Team 1-1, Wilson Fall 2015 Mitglied von IUPUI, Team 1-1, Wilson Fall 2015
IUPUI-WILSON-F15S1G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 16
Letzte 30 Tage: 56
Insgesamt: 2,138
