Einleitung
This guide is used when a disc gets stuck inside of the disc assembly and the disc tray will not eject. Do not put the disc back in the disc assembly when you complete the guide and follow the disc assembly replacement guide to replace the disc assembly. Make sure that the device is unplugged before starting the guide.
Was du brauchst
Remove the three 10mm Philips head screws on the back of the player.
Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
Lift the tabs located on each side of the device to free the front cover. Begin to separate the front and metal back covers.
Completely separate the front cover and the metal back cover from the grey casing.
The inner components should all be completely exposed after opening.
Unscrew the two 8mm Philips head screws securing the disc assembly to the main casing.
To reassemble your device, follow these instructions in reverse order however do not put the disc back in.
