Zum Hauptinhalt wechseln
Sony BDP BX350 Motherboard Replacement
Was du brauchst
  1. Sony BDP BX350 Motherboard Replacement, Disc Assembly: Schritt 1, Bild 1 von 1
    • Remove the three 10mm Philips head screws on the back of the player.
  2. Sony BDP BX350 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
  3. Sony BDP BX350 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Lift the tabs located on each side of the device to free the front cover. Begin to separate the front and metal back covers.
  4. Sony BDP BX350 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Completely separate the front cover and the metal back cover from the grey casing.
    • The inner components should all be completely exposed after opening.
  5. Sony BDP BX350 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the two 8mm Philips head screws securing the disc assembly to the main casing.
  6. Sony BDP BX350 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Pull the disc assembly out from under the metal tabs on the main casing.
  7. Sony BDP BX350 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Remove disc assembly.
  8. Sony BDP BX350 Motherboard Replacement, Motherboard: Schritt 8, Bild 1 von 2 Sony BDP BX350 Motherboard Replacement, Motherboard: Schritt 8, Bild 2 von 2
    • Do not bend or tear the ribbon cable.
    • Remove all five ribbon cables from the motherboard.
  9. Sony BDP BX350 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Unscrew 3mm Philips head HDMI screw from metal casing.
  10. Sony BDP BX350 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Unscrew the three 5mm Philips head screws from motherboard.
    • Separate the motherboard from the metal casing by pulling directly up. Use an opening tool if necessary.
Abschluss
Kristen Vezina
413 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S8-G5, Catania Spring 2017 Mitglied von UMass Dartmouth, Team S8-G5, Catania Spring 2017
UMASSD-CATANIA-S17S8G5
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 19
Insgesamt: 610
