Einleitung
This is a step-by-step guide on how to replace your Sony BDP BX350 Device Motherboard. This guide is needed if the HDMI port or power input port are faulty. Make sure the disc assembly is taken out before starting this guide.
Was du brauchst
Remove the three 10mm Philips head screws on the back of the player.
Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
Lift the tabs located on each side of the device to free the front cover. Begin to separate the front and metal back covers.
Completely separate the front cover and the metal back cover from the grey casing.
The inner components should all be completely exposed after opening.
Unscrew the two 8mm Philips head screws securing the disc assembly to the main casing.
Unscrew the three 5mm Philips head screws from motherboard.
Separate the motherboard from the metal casing by pulling directly up. Use an opening tool if necessary.
