Zum Hauptinhalt wechseln
Sony BDP BX350 Wifi Card Replacement
Was du brauchst
  1. Sony BDP BX350 Wifi Card Replacement, Control Board: Schritt 1, Bild 1 von 1
    • Remove the three 10mm Philips head screws on the back of the player.
  2. Sony BDP BX350 Wifi Card Replacement: Schritt 2, Bild 1 von 1
    • Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
  3. Sony BDP BX350 Wifi Card Replacement: Schritt 3, Bild 1 von 1
    • Lift the tabs located on each side of the device to free the front cover. Begin separating the two covers from metal casing.
  4. Sony BDP BX350 Wifi Card Replacement: Schritt 4, Bild 1 von 1
    • Remove both covers.
  5. Sony BDP BX350 Wifi Card Replacement: Schritt 5, Bild 1 von 2 Sony BDP BX350 Wifi Card Replacement: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Do not bend or tear the ribbon cable.
    • Using the plastic tweezers, carefully remove the ribbon cable from the motherboard.
  6. Sony BDP BX350 Wifi Card Replacement: Schritt 6, Bild 1 von 1
    • Unscrew the one 5mm Phillips head screw from the front of the device board.
  7. Sony BDP BX350 Wifi Card Replacement: Schritt 7, Bild 1 von 2 Sony BDP BX350 Wifi Card Replacement: Schritt 7, Bild 2 von 2
    • Do not bend or tear ribbon cable.
    • Carefully separate the device control board from the metal casing.
  8. Sony BDP BX350 Wifi Card Replacement, Wifi Card: Schritt 8, Bild 1 von 2 Sony BDP BX350 Wifi Card Replacement, Wifi Card: Schritt 8, Bild 2 von 2
    • Remove 6mm Philips head screw from wifi board.
  9. Sony BDP BX350 Wifi Card Replacement: Schritt 9, Bild 1 von 1
    Kaufen
    • Remove the ribbon cable from motherboard using a pair of tweezers.
  10. Sony BDP BX350 Wifi Card Replacement: Schritt 10, Bild 1 von 3 Sony BDP BX350 Wifi Card Replacement: Schritt 10, Bild 2 von 3 Sony BDP BX350 Wifi Card Replacement: Schritt 10, Bild 3 von 3
    • Carefully remove board and ribbon cables by pulling upwards then out to free it from the metal clips.
Abschluss
Kristen Vezina
413 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S8-G5, Catania Spring 2017 Mitglied von UMass Dartmouth, Team S8-G5, Catania Spring 2017
UMASSD-CATANIA-S17S8G5
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 277
