Einleitung
These step-by-step instruction will allow you to replace the disc reader. This may be necessary if your player will not open or stops playing discs, however, before replacing refer to the troubleshooting page for other tips.
Was du brauchst
Plug in the Blu-Ray player, then press the power button, making sure the Blu-Ray player is powered on.
Press the eject button on either the top of the Blu-Ray player or on the remote to open the disc tray.
Grab the sides of the disc tray cover and carefully pull each side upwards, starting with the left side. This will unhook the cover from the tray.
Locate the three 8 mm screws on the back of the Blu-Ray player.
Using the Phillips #2 screwdriver, unscrew each of the screws and set them aside.
Insert the nylon or metal spudger under the clip on the side near the front of the device. Lift the clip so it is free from the device.
Flip device over so the bottom faces you.
Insert the nylon or metal spudger and lift the two clips on the bottom of the device.
Lift the clip on the opposite side of the device with the nylon or metal spudger.
Plug in the device and power it on by pushing the right button on the front of the device. The light should turn on.
Insert the nylon or metal spudger under the clip and lift it up. There are 4 clips that need to be lifted, two on each side
Use the tweezers to lift both sides of the black clip holding the white 14 pin ribbon in place.
Once free the white 24 pin ribbon should slip right out.
Eine weitere Person hat diese Anleitung absolviert.
