Was du brauchst
Plug in the Blu-Ray player, then press the power button, making sure the Blu-Ray player is powered on.
Press the eject button on either the top of the Blu-Ray player or on the remote to open the disc tray.
Grab the sides of the disc tray cover and carefully pull each side upwards, starting with the left side. This will unhook the cover from the tray.
Locate the three 8 mm screws on the back of the Blu-Ray player.
Using the Phillips #2 screwdriver, unscrew each of the screws and set them aside.
Insert the nylon or metal spudger under the clip on the side near the front of the device. Lift the clip so it is free from the device.
Flip device over so the bottom faces you.
Insert the nylon or metal spudger and lift the two clips on the bottom of the device.
Lift the clip on the opposite side of the device with the nylon or metal spudger.
Using a Phillips #2 screwdriver, remove the two silver 8 mm screws on the right side of the disk tray .
Pull the medium-sized 9 pin ribbon cable out of its connector on the motherboard.
Using tweezers, lift up the tab of the large 45 pin connector on the motherboard.
Pull the large 45 pin ribbon cable out of its connector.
Slide the disk tray out from under the tabs on the case holding it down while lifting it out of the case.
6 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Thanks, this helped a lot. I still cant get the DVD drawer to eject with the eject button. The power light will not turn off.
Thank you thank you thank you. I spent an hour on the phone with Sony “technical support “ and was told nothing could be done except to send it off for servicing. This worked PERFECTLY!!!! THANKS AGAIN ?
