Einleitung
In this guide you will learn how to remove the disk drive from a Sony BDP-BX620.
Was du brauchst
Power on the device, eject the disk tray, and power off the device.
Turn the device over.
Lightly apply downward pressure on the black covering on the disk tray until it comes off.
Turn the device around.
Using a Phillips screw driver, remove the screws on both ends of the device circled red in the image.
Slide the side covers on either side towards the back of the device.
Turn the device so that the bottom is facing up.
In the bottom, unclip the three plastic clips circled in red.
On either side, unclip the plastic clip circled in red
Slide the black covering forwards to remove.
Remove the no-fuss ribbon cable connectors by gently pulling on them.
Turn the device over and use tweezers to push the metal clasp until it comes off.
Lift the metal brace located over the disk drive and remove the disk drive and the metal brace.
