Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Power on the device, eject the disk tray, and power off the device. Turn the device over.
    • Power on the device, eject the disk tray, and power off the device.
    • Turn the device over.
    • Lightly apply downward pressure on the black covering on the disk tray until it snaps off.
    • Caution, applying too much pressure can break the black covering.
  2. Turn the device around. Using a Phillips screw driver, remove the screws on both ends of the device circled red in the image.
    • Turn the device around.
    • Using a Phillips screw driver, remove the screws on both ends of the device circled red in the image.
    • Slide the side covers on either side towards the back of the device.
    • There is a back cover on either side of the device.
  3. This step might require someone to help unclasping the plastic clips. Turn the device so that the bottom is facing up. In the bottom, unclip the three plastic clips circled in red.
    • This step might require someone to help unclasping the plastic clips.
    • Turn the device so that the bottom is facing up.
    • In the bottom, unclip the three plastic clips circled in red.
    • On either side, unclip the plastic clip circled in red
    • Slide the black covering forwards to remove.
    • All five clips have to be unclasped for the covering to be removed.
    • Careful not to break the plastic clips when putting it back on.
  4. Now, spot the large ribbon cable that connects between the motherboard and the port board. Remove the cable by pulling upwards.
    • Now, spot the large ribbon cable that connects between the motherboard and the port board.
    • Remove the cable by pulling upwards.
    • Be careful when pulling upwards on the ribbon cable. Too much force can cause it to rip.
  5. Use your Phillips screwdriver to take out the silver screw holding in the port board.
    • Use your Phillips screwdriver to take out the silver screw holding in the port board.
  6. Now use the tweezers to unclip the portboard on the side.
    • Now use the tweezers to unclip the portboard on the side.
Abschluss
Zachery Zavala
175 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 1-6, Lacy Fall 2016 Mitglied von USF Tampa, Team 1-6, Lacy Fall 2016
USFT-LACY-F16S1G6
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 106
