Einleitung
Open up the optical drive and take it apart until you get to the motor. This guide is a bit more difficult than simply unscrewing, but definitely doable. Also, you get to see the inside of the optical drive, which is pretty cool.
Was du brauchst
Remove the 12mm screws with the Philips #2 screwdriver which keep the plastic panels in place.
Don't forget, there are two more 12mm screws on the other side as well.
First, remove the three 12mm black screws holding the top panel on (Phillips #2).
Then, remove the two 12mm black screws - one on each side of the back of the device - holding the top panel on.
Lastly, remove the three 12mm black screws on each side of device.
After gently disconnecting the two ribbon cables (you can just pull them out with your hand), take the top off and set it to the side.
After the top is off, you'll see that there are two metal bars that go across the top of the device.
Remove each bar by unscrewing the two 10mm silver screws on each end.
Remove the two 10mm silver screws holding the front panel on with the Phillips #2 screwdriver, located on the top side of the front panel.
Take off the front panel by depressing the clips (either with your fingers, screwdriver, or other small object) and pulling it off.
Before unscrewing the optical drive enclosure, the small cable on the left of the drive (when looking at the device from the back) needs to be disconnected from the circuit board (the orange one).
Also, take the cables out of the white clip that is on the side of the optical drive.
Unscrew the two metal clamps on both sides of the optical drive by removing three sets of screws:
The two 10mm silver screws on the bottom of the each clamp.
The 10mm silver screw holding each clamp from the front.
The two 5mm black screws on the sides.
Remove the two clamps. They can be removed by hand.
Gently pull the optical drive back to dislodge it from the front of the device and then lift it up.
Remove the wide ribbon cable from the back of the optical drive.
Set aside the rest of the blu ray player; the only part you will need for this guide is the optical drive.
Remove the four 10mm silver screws on the bottom of the optical drive.
Remove the 10mm silver screw on each side of the optical drive.
Remove the single 6mm silver screw on the top of the optical drive.
Any tape or foil strips need to be removed or cut before the drive can be opened (look at first image for example).
Pull off the bottom metal panel of the optical drive. You will see the main circuit board underneath.
Remove the two, 20mm silver screws holding the circuit board in place.
Before removing the circuit board, you will need to disconnect the blue ribbon cable, two orange ribbon cables, and a small connector (look at second image for where the small connector is).
Now you can see the inside of the optical drive. The motor is held in by three small 5mm silver screws. Remove them.
Lift up the motor and replace it with a new one. Now you just need to put it back together!
Eine weitere Person hat diese Anleitung absolviert.
