Zum Hauptinhalt wechseln
Sony BDP-S1: Getting inside the device
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. Sony BDP-S1: Getting inside the device, Sony BDP-S1: Getting inside the device: Schritt 1, Bild 1 von 2 Sony BDP-S1: Getting inside the device, Sony BDP-S1: Getting inside the device: Schritt 1, Bild 2 von 2
    • Remove the 12mm screws with the Philips #2 screwdriver which keep the plastic panels in place.
    • Don't forget, there are two more 12mm screws on the other side as well.
  2. Sony BDP-S1: Getting inside the device: Schritt 2, Bild 1 von 3 Sony BDP-S1: Getting inside the device: Schritt 2, Bild 2 von 3 Sony BDP-S1: Getting inside the device: Schritt 2, Bild 3 von 3
    • First, remove the three 12mm black screws holding the top panel on (Phillips #2).
    • Then, remove the two 12mm black screws - one on each side of the back of the device - holding the top panel on.
    • Lastly, remove the three 12mm black screws on each side of device.
  3. Sony BDP-S1: Getting inside the device: Schritt 3, Bild 1 von 3 Sony BDP-S1: Getting inside the device: Schritt 3, Bild 2 von 3 Sony BDP-S1: Getting inside the device: Schritt 3, Bild 3 von 3
    • Carefully lift up the top panel, because there are two blue ribbon cables that must be disconnected before removing the panel, and we do NOT want them to break.
    • After gently disconnecting the two ribbon cables (you can just pull them out with your hand), take the top off and set it to the side.
  4. Sony BDP-S1: Getting inside the device: Schritt 4, Bild 1 von 3 Sony BDP-S1: Getting inside the device: Schritt 4, Bild 2 von 3 Sony BDP-S1: Getting inside the device: Schritt 4, Bild 3 von 3
    • After the top is off, you'll see that there are two metal bars that go across the top of the device.
    • Remove each bar by unscrewing the two 10mm silver screws on each end.
Abschluss
Sam
376 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 9-30, Maness Winter 2014 Mitglied von Cal Poly, Team 9-30, Maness Winter 2014
CPSU-MANESS-W14S9G30
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 45
