Einleitung
This guide shows how to replace the disc drive in the Sony BDP-S3700.
Was du brauchst
Use the PH1 screwdriver to remove the two 9mm screws on the back of the Blu-ray player.
Remove the back of the device by slowly sliding the rear outer housing backwards.
Flip the Blu-ray back up
Remove the three ribbon cables that connect the disc drive to the motherboard.
Use a PH1 screwdriver to unscrew both of the 7mm screws on the side of the disc reader.
Gently slide the disc drive to the right and lift up to remove the disc drive from the body of the player.
3 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Bei mein dvd Player geht das Netflix nicht und ich habe keine dvd da zu bekommen
