Einleitung
The motherboard is the brain of the Sony BDP-S3700. This guide shows how to replace a faulty one.
Was du brauchst
Use the PH1 screwdriver to remove the two 9mm screws on the back of the Blu-ray player.
Remove the back of the device by slowly sliding the rear outer housing backwards.
Flip the Blu-ray back up
Remove the three ribbon cables that connect the disc drive to the motherboard.
Use a PH1 screwdriver to unscrew both of the 7mm screws on the side of the disc reader.
Gently slide the disc drive to the right and lift up to remove the disc drive from the body of the player.
Gently pull upwards on the ribbon cables to disconnect the motherboard from the Wi-Fi module and port board.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Thanks for the guide really good! Does anyone know where i can get a sony bdp-s3700 motherboard replacement?
Same problem here.
