Einleitung
Sometimes you may need to replace the back cover to prevent excess dust or other material from entering the device and potentially damaging other components. This guide will show you how to replace the back cover in case yours is damaged beyond repair.
Was du brauchst
Using the Phillips #2 Screwdriver, remove the five 9mm from the bottom of the device.
Remove the metal cover.
Using the Phillips #2 Screwdriver, remove the six 9mm screws from the back of the device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
