Einleitung
This guide will detail the steps necessary to remove the back cover of the Sony Bloggie 3D Player.
Was du brauchst
Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
Use a plastic opening tool to pry the cover open.
After the the cover is partly open as shown, remove the cover with your hands.
Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
Use a plastic opening tool to loosen the back cover off the device.
Once the back cover is loose, remove it gently by hand.
