Zum Hauptinhalt wechseln
Sony Bloggie 3D Player Battery Replacement
Was du brauchst
  1. Sony Bloggie 3D Player Battery Replacement, Front Cover: Schritt 1, Bild 1 von 1
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Sony Bloggie 3D Player Battery Replacement: Schritt 2, Bild 1 von 2 Sony Bloggie 3D Player Battery Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  3. Sony Bloggie 3D Player Battery Replacement, Back Cover: Schritt 3, Bild 1 von 2 Sony Bloggie 3D Player Battery Replacement, Back Cover: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
  4. Sony Bloggie 3D Player Battery Replacement: Schritt 4, Bild 1 von 2 Sony Bloggie 3D Player Battery Replacement: Schritt 4, Bild 2 von 2
    • Use a plastic opening tool to loosen the back cover off the device.
    • Once the back cover is loose, remove it gently by hand.
  5. Sony Bloggie 3D Player Battery Replacement, Battery: Schritt 5, Bild 1 von 2 Sony Bloggie 3D Player Battery Replacement, Battery: Schritt 5, Bild 2 von 2
    • Remove the battery with your fingers.
Abschluss
Timothy Tran
1 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 7-12, Maness Winter 2013 Mitglied von Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
You forgot to mention the need to flip the screen up (a screw holds it down) in order to get to a screw holding the back cover. Other than that, thank you for the info.
Rich Brewer - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 2,185
