Einleitung
This will help you to remove the front cover so you can get to the other parts of the Bloggie 3D Camera.
Was du brauchst
Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
Use a plastic opening tool to pry the cover open.
After the the cover is partly open as shown, remove the cover with your hands.
Fast fertig!
Abschluss
