Einleitung
Whether it's due to dust, wear, or physical damage, the main button circuit board may need to be replaced at some point. This guide focuses on how to install a new main button circuit board to get your Sony Bloggie 3D Player running like new.
Was du brauchst
Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
Use a plastic opening tool to pry the cover open.
After the the cover is partly open as shown, remove the cover with your hands.
