Zum Hauptinhalt wechseln
Sony Bloggie 3D Player Main Button's Circuit Board Replacement
Was du brauchst
  1. Sony Bloggie 3D Player Main Button's Circuit Board Replacement, Front Cover: Schritt 1, Bild 1 von 1
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Sony Bloggie 3D Player Main Button's Circuit Board Replacement: Schritt 2, Bild 1 von 2 Sony Bloggie 3D Player Main Button's Circuit Board Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  3. Sony Bloggie 3D Player Main Button's Circuit Board Replacement, Main Button's Circuit Board: Schritt 3, Bild 1 von 2 Sony Bloggie 3D Player Main Button's Circuit Board Replacement, Main Button's Circuit Board: Schritt 3, Bild 2 von 2
    • Detach the board from the ZIF connector using a pair of tweezers or by hand.
    • Flip the circuit board over and remove the connector on the backside. Now you can safely remove the circuit board.
Abschluss
Robert Tam
6 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 7-12, Maness Winter 2013 Mitglied von Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 10
Insgesamt: 375
