Zum Hauptinhalt wechseln
Sony Bloggie 3D Player On/Off Buttons Replacement
Was du brauchst
  1. Sony Bloggie 3D Player On/Off Buttons Replacement, Front Cover: Schritt 1, Bild 1 von 1
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Sony Bloggie 3D Player On/Off Buttons Replacement: Schritt 2, Bild 1 von 2 Sony Bloggie 3D Player On/Off Buttons Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  3. Sony Bloggie 3D Player On/Off Buttons Replacement, Back Cover: Schritt 3, Bild 1 von 2 Sony Bloggie 3D Player On/Off Buttons Replacement, Back Cover: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
  4. Sony Bloggie 3D Player On/Off Buttons Replacement: Schritt 4, Bild 1 von 2 Sony Bloggie 3D Player On/Off Buttons Replacement: Schritt 4, Bild 2 von 2
    • Use a plastic opening tool to loosen the back cover off the device.
    • Once the back cover is loose, remove it gently by hand.
  5. Sony Bloggie 3D Player On/Off Buttons Replacement, On/Off Buttons: Schritt 5, Bild 1 von 1
    • Using a spudger, carefully remove the metal casing that is attached to the ZIF connector.
  6. Sony Bloggie 3D Player On/Off Buttons Replacement: Schritt 6, Bild 1 von 1
    • Unclip the two plastic buttons with the spudger tool.
    • The buttons each have a spring under them that will fall off, be careful not to lose them.
Abschluss
Fred Saucedo
3 Reputation
1 Anleitung geschrieben
Cal Poly, Team 7-12, Maness Winter 2013 Mitglied von Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 302
