Einleitung
The USB is a very important part of the Sony Bloggie as it is the only way to get your movies from the camera to a computer. This guide will show you how to install a new USB drive in the Sony Bloggie 3D.
  1. Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Use a plastic opening tool to pry the cover open. After the the cover is partly open as shown, remove the cover with your hands.
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  3. Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board. Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
    • Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
  4. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Schon mal was repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  5. Use a plastic opening tool to loosen the back cover off the device. Once the back cover is loose, remove it gently by hand.
    • Use a plastic opening tool to loosen the back cover off the device.
    • Once the back cover is loose, remove it gently by hand.
  6. Once the back cover is removed, by using the opening tool, remove the following screws using a Phillips #00 screwdriver. Two 4.0mm Phillips #00 screws
    • Once the back cover is removed, by using the opening tool, remove the following screws using a Phillips #00 screwdriver.
      • Two 4.0mm Phillips #00 screws
      • One 8.0mm Phillips #00 screw
      • One 9.5mm Phillips #00 screw
  7. Using a spudger, remove the clips of the metal casing from each end of the USB drive. Using a spudger, remove the clips of the metal casing from each end of the USB drive.
    • Using a spudger, remove the clips of the metal casing from each end of the USB drive.
  8. Carefully lift the USB drive off of the peg that it is attached to. Carefully lift the USB drive off of the peg that it is attached to.
    • Carefully lift the USB drive off of the peg that it is attached to.
  9. Now that the USB component is on its own, untangle the ribbon from inside the device.
    • Now that the USB component is on its own, untangle the ribbon from inside the device.
  10. Now remove the ZIF connector from the device using a pair of tweezers.
    • Now remove the ZIF connector from the device using a pair of tweezers.
Abschluss
Craig Sweet
1 Reputation
1 Anleitung geschrieben
Cal Poly, Team 7-12, Maness Winter 2013 Mitglied von Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 Mitglieder
6 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 338
