Zum Hauptinhalt wechseln
Sony CDX-GT540UI CD Drive Replacement
Was du brauchst
  1. Sony CDX-GT540UI CD Drive Replacement, Front Panel: Schritt 1, Bild 1 von 1
    • Locate face-plate eject button.
  2. Sony CDX-GT540UI CD Drive Replacement: Schritt 2, Bild 1 von 2 Sony CDX-GT540UI CD Drive Replacement: Schritt 2, Bild 2 von 2
    • Press the eject button.
    • Remove the face-plate.
  3. Sony CDX-GT540UI CD Drive Replacement: Schritt 3, Bild 1 von 3 Sony CDX-GT540UI CD Drive Replacement: Schritt 3, Bild 2 von 3 Sony CDX-GT540UI CD Drive Replacement: Schritt 3, Bild 3 von 3
    • Remove two 4.9mm Phillips #00screws on the front of the device.
    • Remove two 7.5mm Phillips #00screws on the front of the device.
    • When the screws are removed, the eject lever may fall into the device. Make sure the device is held horizontal and level.
  4. Sony CDX-GT540UI CD Drive Replacement: Schritt 4, Bild 1 von 2 Sony CDX-GT540UI CD Drive Replacement: Schritt 4, Bild 2 von 2
    • Rotate device 90 degrees to either side.
    • Use the plastic opening tool to pry open the top and bottom tab respectively.
    • Repeat on opposite side.
  5. Sony CDX-GT540UI CD Drive Replacement: Schritt 5, Bild 1 von 1
    • Remove front panel.
  6. Sony CDX-GT540UI CD Drive Replacement, Back Panel: Schritt 6, Bild 1 von 1
    • Locate back panel.
  7. Sony CDX-GT540UI CD Drive Replacement: Schritt 7, Bild 1 von 3 Sony CDX-GT540UI CD Drive Replacement: Schritt 7, Bild 2 von 3 Sony CDX-GT540UI CD Drive Replacement: Schritt 7, Bild 3 von 3
    • Remove four 11.5mm Phillips #00 (silver) screws from back panel.
  8. Sony CDX-GT540UI CD Drive Replacement: Schritt 8, Bild 1 von 1
    • Remove four 9.5mm Phillips #00 (black) screws from back panel.
    • Remove two 7.5mm Phillips #00 (black) screws from back panel.
  9. Sony CDX-GT540UI CD Drive Replacement: Schritt 9, Bild 1 von 1
    • Remove back panel.
    • On the back panel there will be thermal (white) paste. Do not touch.
  10. Sony CDX-GT540UI CD Drive Replacement, CD Drive: Schritt 10, Bild 1 von 1
    • Remove one 9.5mm Phillips #00 screw.
    • Rotate device 180 degrees and repeat step.
  11. Sony CDX-GT540UI CD Drive Replacement: Schritt 11, Bild 1 von 2 Sony CDX-GT540UI CD Drive Replacement: Schritt 11, Bild 2 von 2
    • Using plastic opening tool, detach the tabs. There are two on either side.
    • You will need to apply a decent amount of force to detach.
  12. Sony CDX-GT540UI CD Drive Replacement: Schritt 12, Bild 1 von 2 Sony CDX-GT540UI CD Drive Replacement: Schritt 12, Bild 2 von 2
    • Remove top panel.
  13. Sony CDX-GT540UI CD Drive Replacement: Schritt 13, Bild 1 von 1
    • Pull up CD drive slightly.
  14. Sony CDX-GT540UI CD Drive Replacement: Schritt 14, Bild 1 von 1
    • Disconnect motherboard connection.
  15. Sony CDX-GT540UI CD Drive Replacement: Schritt 15, Bild 1 von 1
    • Remove CD drive.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Odelkys Marquez
1.115 Reputation
7 Anleitungen geschrieben
USF Tampa, Team 10-2, Brown Fall 2014 Mitglied von USF Tampa, Team 10-2, Brown Fall 2014
USFT-BROWN-F14S10G2
3 Mitglieder
Ein Kommentar
This guide is listed as "difficult" yet only requires the use of a screwdriver and some prying tools. It would seem more appropriate to list it as "moderate" at most. I believe the motherboard guide has the same issue.
Also, you say PH#00 in the description of steps, but in the "tools" listing at the beginning of the guide, you said that a PH#0 was needed. These are not the same.
Dale Pearson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 744
