Zum Hauptinhalt wechseln
Einleitung
This will be the initial step for getting into your device for repair.
Before any repair work can be done, one must remove the device from the vehicle. To do so follow this link to see a vehicle general removal of a stereo system.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Locate face-plate eject button.
    • Locate face-plate eject button.
  2. Press the eject button. Remove the face-plate.
    • Press the eject button.
    • Remove the face-plate.
  3. Android Fix Kits
    Ein neues Display oder Akku sind nur ein Kit entfernt.
    Jetzt kaufen
    Android Fix Kits
    Jetzt kaufen
  4. Remove two 4.9mm Phillips #00screws on the front of the device. Remove two 7.5mm Phillips #00screws on the front of the device. When the screws are removed, the eject lever may fall into the device. Make sure the device is held horizontal and level.
    • Remove two 4.9mm Phillips #00screws on the front of the device.
    • Remove two 7.5mm Phillips #00screws on the front of the device.
    • When the screws are removed, the eject lever may fall into the device. Make sure the device is held horizontal and level.
  5. Rotate device 90 degrees to either side. Use the plastic opening tool to pry open the top and bottom tab respectively.
    • Rotate device 90 degrees to either side.
    • Use the plastic opening tool to pry open the top and bottom tab respectively.
    • Repeat on opposite side.
  6. Remove front panel.
    • Remove front panel.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Odelkys Marquez
998 Reputation
7 Anleitungen geschrieben
USF Tampa, Team 10-2, Brown Fall 2014 Mitglied von USF Tampa, Team 10-2, Brown Fall 2014
USFT-BROWN-F14S10G2
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 23
Insgesamt: 1,892
