Einleitung
Use this guide if your radio is not working and the antenna needs to be replaced. This is an easy part to replace and requires a standard Phillips #1 screwdriver.
Was du brauchst
Unscrew the screw attaching the antenna to the boombox with a Phillips #1 screwdriver.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
