Einleitung
If your device is not turning on and you're using batteries as a power source, you can use this guide to remove or replace the batteries. Be sure to remove the batteries and unplug the device before taking it apart to avoid electric shock.
  1. Remove the battery cover on the back of the boombox by applying downward pressure to the two clamps. Be sure to unplug the boombox from the wall before attempting to open it for repair. Be sure to unplug the boombox from the wall before attempting to open it for repair.
    • Remove the battery cover on the back of the boombox by applying downward pressure to the two clamps.
      • Be sure to unplug the boombox from the wall before attempting to open it for repair.
  2. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  3. Push against the positive end of each battery. Once it is loose, lift the battery out. Repeat for all six batteries. The top row of batteries have the positive side pointing right. The bottom row of batteries have the positive side pointing left.
    • Push against the positive end of each battery. Once it is loose, lift the battery out. Repeat for all six batteries.
      • The top row of batteries have the positive side pointing right. The bottom row of batteries have the positive side pointing left.
Abschluss
Tess
427 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 10-38, Amido Fall 2014 Mitglied von Cal Poly, Team 10-38, Amido Fall 2014
CPSU-AMIDO-F14S10G38
5 Mitglieder
7 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 522
