Zum Hauptinhalt wechseln
Sony CFS-204 Radio Cassette-Corder Batteries Replacement
Was du brauchst
  1. Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: Schritt 1, Bild 1 von 1
    • Press down on the two tabs at the top of the door.
    • Rotate the door away from the radio, towards you.
    • Lift the door out of the three smaller tabs on the bottom.
    • Ensure the radio is turned off to avoid the possibility of electric shock.
    • The battery compartment door is not shown.
  2. Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: Schritt 2, Bild 1 von 3 Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: Schritt 2, Bild 2 von 3 Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: Schritt 2, Bild 3 von 3
    • Push the batteries against the spring and pull out using your finger to remove them.
    • To insert the new batteries, push the negative end of the 1st battery against a spring and follow the diagram pictured to insert the batteries in the correct orientation.
Abschluss
Daniel
236 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 36
Insgesamt: 1,877
