Zum Hauptinhalt wechseln
Sony CFS-204 Radio Cassette-Corder Speaker Replacement
Was du brauchst
  1. Sony CFS-204 Radio Cassette-Corder Speaker Replacement, Batteries: Schritt 1, Bild 1 von 1
    • Press down on the two tabs at the top of the door.
    • Rotate the door away from the radio, towards you.
    • Lift the door out of the three smaller tabs on the bottom.
    • Ensure the radio is turned off to avoid the possibility of electric shock.
    • The battery compartment door is not shown.
  2. Sony CFS-204 Radio Cassette-Corder Speaker Replacement, Batteries: Schritt 2, Bild 1 von 3 Sony CFS-204 Radio Cassette-Corder Speaker Replacement, Batteries: Schritt 2, Bild 2 von 3 Sony CFS-204 Radio Cassette-Corder Speaker Replacement, Batteries: Schritt 2, Bild 3 von 3
    • Push the batteries against the spring and pull out using your finger to remove them.
    • To insert the new batteries, push the negative end of the 1st battery against a spring and follow the diagram pictured to insert the batteries in the correct orientation.
  3. Sony CFS-204 Radio Cassette-Corder Speaker Replacement, Screws: Schritt 3, Bild 1 von 3 Sony CFS-204 Radio Cassette-Corder Speaker Replacement, Screws: Schritt 3, Bild 2 von 3 Sony CFS-204 Radio Cassette-Corder Speaker Replacement, Screws: Schritt 3, Bild 3 von 3
    • Remove the 6 screws (30 mm in length) with the Phillips #2 Screwdriver from the large holes marked by arrows on the radio.
  4. Sony CFS-204 Radio Cassette-Corder Speaker Replacement, Opening: Schritt 4, Bild 1 von 1
    • Press the EJECT button to open the cassette deck.
    • Pressing this button is required to allow the front face to separate from the case.
  5. Sony CFS-204 Radio Cassette-Corder Speaker Replacement: Schritt 5, Bild 1 von 2 Sony CFS-204 Radio Cassette-Corder Speaker Replacement: Schritt 5, Bild 2 von 2
    • Grasp the radio from the front and back halves and gently pull apart to separate them.
  6. Sony CFS-204 Radio Cassette-Corder Speaker Replacement: Schritt 6, Bild 1 von 2 Sony CFS-204 Radio Cassette-Corder Speaker Replacement: Schritt 6, Bild 2 von 2
    • Pull the white plug out from the red outlet in the Orange circuit board in the back face of the casing.
    • Take care not to break the red outlet off the circuit board.
    • The front and back portions of the casing are now separated from each other.
  7. Sony CFS-204 Radio Cassette-Corder Speaker Replacement, Glue: Schritt 7, Bild 1 von 1
    • Carefully slice the glue holding the speaker wire at the top right corner of the front face with a sharp tool or a knife to separate the wire from the case.
    • The wire can be tucked into its original location without re-gluing it.
  8. Sony CFS-204 Radio Cassette-Corder Speaker Replacement, Speaker: Schritt 8, Bild 1 von 1
    • Remove the 2 screws (10 mm in length) located on the corners of the speaker with the Phillips #2 screwdriver.
    • There are 4 screw positions; however, our radio only had screws in two of the positions on each speaker.
    • Repeat the process for the second speaker if you need to replace both speakers.
  9. Sony CFS-204 Radio Cassette-Corder Speaker Replacement: Schritt 9, Bild 1 von 1
    • Lift the speakers out of the front face of the radio to complete the removal.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 25
Insgesamt: 2,013
