Einleitung
Use this guide if the speakers do not turn on and you think it is because the power cord in the subwoofer is broken.
Was du brauchst
Remove fourteen 8 mm Phillips #2 screws from the bottom of the subwoofer.
Once all of the screws are removed, the cover can be taken off using a metal spudger.
Remove eight 14 mm Phillips #2 screws holding the circuit board in place.
Using the plastic opening tool, carefully remove the circuit board.
Remove the wire furthest to the left by squeezing the clip and pulling it out.
Detach the third wire by carefully using the tweezers.
The circuit board is now completely detached and can be set aside.
Remove six 8 mm Phillips #2 screws.
Slide the side panel with the power cord out from the housing.
Remove four 8 mm Phillips #2 screws.
Detach the air tube from the side panel.
Begin to pry the power cord cover unit from the side panel using a metal spudger.
Feed the wires that come out of the side panel through the glue and into the power cord cover unit to get the cover farther away from the side panel.
Using a metal spudger, disconnect the four spade connectors that are connected to the power button and the power cord.
Using a metal spudger, press the tab on top of the power cord and push the power cord through the side panel.
Once through, the clip connected to the power cord will open up and a new power cord can be put in place.
