Einleitung
Use this guide if your remote stops functioning. Be sure to have a replacement battery available. The type of battery you will need is a 3 Volt CR2032.
Was du brauchst
Open battery tray by pushing right on the boxed tab and pulling the battery tray out.
Replace battery.
When placing your new battery in the tray, make sure the positive side on the battery and the positive side on the tray are both facing up.
Eine weitere Person hat diese Anleitung absolviert.
