Einleitung
This guide will show you how to replace the subwoofer speaker if you hear muffled or distorted sound coming from the subwoofer unit.
Was du brauchst
Remove fourteen 8 mm Phillips #2 screws from the bottom of the subwoofer.
Once all of the screws are removed, the cover can be taken off using a metal spudger.
Remove eight 14 mm Phillips #2 screws holding the circuit board in place.
Using the plastic opening tool, carefully remove the circuit board.
Remove the wire furthest to the left by squeezing the clip and pulling it out.
Detach the third wire by carefully using the tweezers.
The circuit board is now completely detached and can be set aside.
Remove six 8 mm Phillips #2 screws.
Slide the side panel with the power cord out from the housing.
Remove eight 8 mm Phillips #2 screws holding the subwoofer tray to the housing.
Using a metal spudger, slightly peel back the plastic the has been glued to the tray and the housing.
Slide the tray containing the subwoofer out of the housing.
After removing the tray, flip it over and you will find four screws connecting the subwoofer.
Remove four 7.5 mm Phillips #2 screws.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
