Remove screws from down
Remove screws from sides
Gently take out the from of deck from metal base.
Remove left side black wire
Remove white contact strips
Remove little screw to change ruble inside deck mechanims
Remove power supply grey wires
Remove the small screw
Then you can see the place of the weel. Change the ruble.
Replace the big belt.
Replace the small (green) belt.
Use a little tape to old the belt. When closing remove the tape.
Insert little screw and close the deck with new belts.
Plug all the wires and strips.
Close everything, and your done
Hope it help, please leave a comment.
To reassemble your device, follow these isntructions in reverse order
Besonderer Dank geht an diese Übersetzer*innen:
100%
jeremyfitz hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Beginne zu übersetzen ›
