Einleitung
If your device is having trouble reading memory you probably need to replace the memory module. This guide will show you step-by-step how to install a new memory module.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
Remove the back panel by lifting it away with your hands.
Holding the memory module in place, unscrew the three 0.9mm screws with a Phillips #00 screwdriver.
