Zum Hauptinhalt wechseln
Sony Clie PEG-NR70 Screen Replacement
Was du brauchst
  1. Sony Clie PEG-NR70 Screen Replacement, Screen: Schritt 1, Bild 1 von 1
    • Remove the two 1.5mm screws (one on the right and one on the left side) on the screen portion of the device with a Phillips #00 screwdriver.
  2. Sony Clie PEG-NR70 Screen Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 1.5mm screws on the bottom of the screen module with a Phillips #00 screwdriver.
  3. Sony Clie PEG-NR70 Screen Replacement: Schritt 3, Bild 1 von 1
    • Remove the plastic wrapping on the side of the top portion of the device. This is done by first sliding the wrapping up to disengage the plastic hooks, then peeling the plastic away starting from either end.
  4. Sony Clie PEG-NR70 Screen Replacement: Schritt 4, Bild 1 von 1
    • Remove four 2.0mm screws on the side of the screen portion of the device with a Phillips #00 screwdriver.
  5. Sony Clie PEG-NR70 Screen Replacement: Schritt 5, Bild 1 von 1
    • Remove top .75mm screw of the top portion of device with a Phillips #00 screwdriver.
  6. Sony Clie PEG-NR70 Screen Replacement: Schritt 6, Bild 1 von 1
    • Remove front panel from the screen. You should be able to do this by gently pulling the pieces apart with your hands
  7. Sony Clie PEG-NR70 Screen Replacement: Schritt 7, Bild 1 von 1
    • Pry the screen from the back panel using the plastic opening tools to remove the screen module.
  8. Sony Clie PEG-NR70 Screen Replacement: Schritt 8, Bild 1 von 1
    • Remove the tape from the wires on the back side of the screen module.
  9. Sony Clie PEG-NR70 Screen Replacement: Schritt 9, Bild 1 von 1
    • Disconnect the screen from the device by gently pulling the two display data cables away from the bottom of the screen module with your fingers.
    • Be careful not to damage the display data cables! They are thin.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Courtney
49 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 14-11, Maness Spring 2013 Mitglied von Cal Poly, Team 14-11, Maness Spring 2013
CPSU-MANESS-S13S14G11
5 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 1,019
