Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Installing a new speaker rail fairly simple as it only involves opening the device casing and then removing the broken speaker.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver. Remove the back panel by lifting it away with your hands.
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
  4. Use tweezers to unplug the speaker wire from the motherboard by pulling the plug (not the wires) down towards the speaker. Be careful not to tear the speaker wires! They are very thin.
    • Use tweezers to unplug the speaker wire from the motherboard by pulling the plug (not the wires) down towards the speaker.
    • Be careful not to tear the speaker wires! They are very thin.
    • Remove the tape holding speaker wire by peeling it away.
  5. Holding down the speaker rail unscrew the two 2.5mm screws with a Phillips #00 screwdriver.
    • Holding down the speaker rail unscrew the two 2.5mm screws with a Phillips #00 screwdriver.
    • Remove the speaker rail vertically from the device.
Abschluss
Daniel Soski
20 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 14-11, Maness Spring 2013 Mitglied von Cal Poly, Team 14-11, Maness Spring 2013
CPSU-MANESS-S13S14G11
5 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 219
