Zum Hauptinhalt wechseln
Sony Clie PEG-SL10 Motherboard Replacement
Was du brauchst
  1. Sony Clie PEG-SL10 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Remove the six screws holding the case together.
  2. Sony Clie PEG-SL10 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the seven screws holding the motherboard to the device.
  3. Sony Clie PEG-SL10 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Unclip the battery harness power cable from the motherboard.
  4. Sony Clie PEG-SL10 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Unclip the scroll wheel power cable from the motherboard.
  5. Sony Clie PEG-SL10 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Pull the left clip to remove the cable.
  6. Sony Clie PEG-SL10 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Pull out the two clips from the center to remove the power cable.
  7. Sony Clie PEG-SL10 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Rotate the motherboard toward you to show the cables on the opposite side of the motherboard.
  8. Sony Clie PEG-SL10 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Extend both sides of the left clip to remove the power cable.
  9. Sony Clie PEG-SL10 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Pull out the center clip to remove the power cable.
  10. Sony Clie PEG-SL10 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Pull the right clip out to remove the right cable.
  11. Sony Clie PEG-SL10 Motherboard Replacement: Schritt 11, Bild 1 von 1
    • The motherboard is removed. To install the new motherboard, follow the directions in reverse.
Abschluss
Emily
3 Reputation
3 Anleitungen geschrieben
James Madison, Team 1-4, Allen Fall 2011 Mitglied von James Madison, Team 1-4, Allen Fall 2011
JMU-ALLEN-F11S1G4
3 Mitglieder
4 Anleitungen geschrieben
Ein Kommentar
I have a full reset whenever I take the battery out to recharge it. Given that all replacement motherboards will be as old as the unit, is there anyway to fix the board (I presume it’s a capacitor or super cell that keeps the charge long enough to swap the battery over normally?). The three cells seem to be soldered onto the board, but I presume could be replaced?
Anyone know of a way to fix this?
Benjamin S. Leveritt - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 1,342
