Zum Hauptinhalt wechseln
Sony Clie PEG-T615C Battery Replacement
Was du brauchst
  1. Sony Clie PEG-T615C Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove two screws from the thumb dial panel on the back of the device.
  2. Sony Clie PEG-T615C Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove one screw from the upper right corner on the back of the device.
  3. Sony Clie PEG-T615C Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove one screw from the thumb dial panel on the right side of the device.
  4. Sony Clie PEG-T615C Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove one screw from lower right side of the device.
  5. Sony Clie PEG-T615C Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove one screw from the lower left side of the device.
  6. Sony Clie PEG-T615C Battery Replacement: Schritt 6, Bild 1 von 1
    • Remove two screws from the bottom of the device.
  7. Sony Clie PEG-T615C Battery Replacement: Schritt 7, Bild 1 von 1
    • Remove the thumb dial panel by sliding it away from the device.
    • You can do this step earlier, after you remove all of the screws from the thumb drive panel.
  8. Sony Clie PEG-T615C Battery Replacement: Schritt 8, Bild 1 von 1
    • Remove the back panel, exposing the inside of the device.
  9. Sony Clie PEG-T615C Battery Replacement: Schritt 9, Bild 1 von 1
    • Remove one screw located on the board below the battery.
  10. Sony Clie PEG-T615C Battery Replacement: Schritt 10, Bild 1 von 1
    • Unplug the male battery plug on the battery wire from the female battery plug on the board.
  11. Sony Clie PEG-T615C Battery Replacement: Schritt 11, Bild 1 von 1
    • Remove the battery by sliding it out of the side of the device.
Abschluss
Rob
1 Reputation
2 Anleitungen geschrieben
UW Stout, Team 5-6, Zhou Fall 2011 Mitglied von UW Stout, Team 5-6, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G6
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 2,279
