Zum Hauptinhalt wechseln
Sony Clie PEG-T615C Thumb Dial Replacement
Was du brauchst
  1. Sony Clie PEG-T615C Thumb Dial Replacement, Thumb Dial: Schritt 1, Bild 1 von 1
    • First, place the device with the screen side facing down. Remove the 2 screws from the thumb dial panel located on the upper right hand side.
  2. Sony Clie PEG-T615C Thumb Dial Replacement: Schritt 2, Bild 1 von 1
    • Remove the screw directly above the thumb dial panel.
  3. Sony Clie PEG-T615C Thumb Dial Replacement: Schritt 3, Bild 1 von 1
    • Remove the screw from thumb dial panel on the right handed side of the device.
  4. Sony Clie PEG-T615C Thumb Dial Replacement: Schritt 4, Bild 1 von 1
    • Remove screw from lower right side of the device.
  5. Sony Clie PEG-T615C Thumb Dial Replacement: Schritt 5, Bild 1 von 1
    • Remove 1 screw from the lower left side of the device.
  6. Sony Clie PEG-T615C Thumb Dial Replacement: Schritt 6, Bild 1 von 1
    • On the bottom of the device, remove both the left and right screws.
  7. Sony Clie PEG-T615C Thumb Dial Replacement: Schritt 7, Bild 1 von 1
    • Remove the thumb dial panel by sliding it away from the device.
  8. Sony Clie PEG-T615C Thumb Dial Replacement: Schritt 8, Bild 1 von 1
    • Remove the back panel exposing the inside of the device.
  9. Sony Clie PEG-T615C Thumb Dial Replacement: Schritt 9, Bild 1 von 1
    • Locate thumb dial on top right side of the board.
  10. Sony Clie PEG-T615C Thumb Dial Replacement: Schritt 10, Bild 1 von 1
    • Follow ribbon wire to locate where it plugs into the board. The plug is a flat black square.
  11. Sony Clie PEG-T615C Thumb Dial Replacement: Schritt 11, Bild 1 von 1
    • Pull plug straight up to remove from board.
Abschluss
Rob
1 Reputation
2 Anleitungen geschrieben
UW Stout, Team 5-6, Zhou Fall 2011 Mitglied von UW Stout, Team 5-6, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G6
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 1,076
