Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Before taking apart your device, make sure that you have the proper tools to do so. We used a small screwdriver to remove the screws because they are so tiny. Also, make sure that you are working in an area that is clean and clear of debris so you can see all the parts of your device as you take it apart.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Use a #00 Phillips screwdriver to remove screws on the back plate and the side of the device. Use a #00 Phillips screwdriver to remove screws on the back plate and the side of the device.
    • Use a #00 Phillips screwdriver to remove screws on the back plate and the side of the device.
  2. Remove the small top grey piece from the back plate. Detach the back plate from the rest of the device.
    • Remove the small top grey piece from the back plate.
    • Detach the back plate from the rest of the device.
  3. Use the #00 Phillips screwdriver to loosen and remove the screws on the motherboard.
    • Use the #00 Phillips screwdriver to loosen and remove the screws on the motherboard.
  4. Remove the volume rocker from the side panel of the device.
    • Remove the volume rocker from the side panel of the device.
  5. Loosen the battery from the motherboard.
    • Loosen the battery from the motherboard.
    • Replace the battery with a new one.
Abschluss
Alyson
11 Reputation
1 Anleitung geschrieben
James Madison, Team 1-2, Allen Fall 2011 Mitglied von James Madison, Team 1-2, Allen Fall 2011
JMU-ALLEN-F11S1G2
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 3
Letzten 30 Tage: 7
Insgesamt: 1,927
