Einleitung
Rear Cover Removal allows the inside of the Clie to be exposed for further replacement of internal components
Was du brauchst
Using Phillips screwdriver, remove 4 screws from the rear cover.
Remove 1 screw from the right side.
Remove 1 screw from the top.
Slowly pull rear cover from device being careful not to pull the speaker connection wire.
Remove speaker wire from device.
The rear cover is now separated from the device.
