Einleitung
The Sony Clie PEG-UX50 has a separate tilt screen display. This guide will show you how to remove the tilt screen without dismantling the battery plate.
Was du brauchst
Take off the screws located on the two sides of the tilt screen.
Unscrew the screw located at the tilt base of the screen.
Fast fertig!
Follow these instructions in reverse order to reassemble your device.
Abschluss
