Zum Hauptinhalt wechseln
Sony Cyber-Shot DSC-H1 LCD Screen Replacement
Was du brauchst
  1. Sony Cyber-Shot DSC-H1 LCD Screen Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Power down the camera and remove the batteries.
  2. Sony Cyber-Shot DSC-H1 LCD Screen Replacement: Schritt 2, Bild 1 von 3 Sony Cyber-Shot DSC-H1 LCD Screen Replacement: Schritt 2, Bild 2 von 3 Sony Cyber-Shot DSC-H1 LCD Screen Replacement: Schritt 2, Bild 3 von 3
    • Using a Phillips #0 screwdriver, remove all of the screws from the back panel casing.
    • There are six 5.22mm long, 3.00mm head diameter screws total.
    • The left side is not shown but there should be 1 screw on that side.
  3. Sony Cyber-Shot DSC-H1 LCD Screen Replacement: Schritt 3, Bild 1 von 2 Sony Cyber-Shot DSC-H1 LCD Screen Replacement: Schritt 3, Bild 2 von 2
    • Remove the back casing.
    • The casing itself is sturdy so don't be afraid to remove it forcefully.
  4. Sony Cyber-Shot DSC-H1 LCD Screen Replacement, LCD Screen: Schritt 4, Bild 1 von 1
    • Take a hold of the right side of the LCD screen and lift it towards the left.
    • The screen is held firm and will require a bit of force to ease it from its housing.
  5. Sony Cyber-Shot DSC-H1 LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Unplug the large conductive tape attached to the screen.
    • Remove the LCD from the device.
Abschluss
Trystan Jasperson
231 Reputation
2 Anleitungen geschrieben
Baylor, Team S5-G4, Williams Spring 2018 Mitglied von Baylor, Team S5-G4, Williams Spring 2018
BU-WILLIAMS-S18S5G4
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 21
Insgesamt: 672
