Zum Hauptinhalt wechseln
Sony Cyber-Shot DSC-H1 Lens Replacement
Was du brauchst
  1. Sony Cyber-Shot DSC-H1 Lens Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Power down the camera and remove the batteries.
  2. Sony Cyber-Shot DSC-H1 Lens Replacement: Schritt 2, Bild 1 von 3 Sony Cyber-Shot DSC-H1 Lens Replacement: Schritt 2, Bild 2 von 3 Sony Cyber-Shot DSC-H1 Lens Replacement: Schritt 2, Bild 3 von 3
    • Using a Phillips #0 screwdriver, remove all of the screws from the back panel casing.
    • There are six 5.22mm long, 3.00mm head diameter screws total.
    • The left side is not shown but there should be 1 screw on that side.
  3. Sony Cyber-Shot DSC-H1 Lens Replacement: Schritt 3, Bild 1 von 2 Sony Cyber-Shot DSC-H1 Lens Replacement: Schritt 3, Bild 2 von 2
    • Remove the back casing.
    • The casing itself is sturdy so don't be afraid to remove it forcefully.
  4. Sony Cyber-Shot DSC-H1 Lens Replacement, LCD Screen: Schritt 4, Bild 1 von 1
    • Take a hold of the right side of the LCD screen and lift it towards the left.
    • The screen is held firm and will require a bit of force to ease it from its housing.
  5. Sony Cyber-Shot DSC-H1 Lens Replacement: Schritt 5, Bild 1 von 1
    • Unplug the large conductive tape attached to the screen.
    • Remove the LCD from the device.
  6. Sony Cyber-Shot DSC-H1 Lens Replacement, Lens: Schritt 6, Bild 1 von 2 Sony Cyber-Shot DSC-H1 Lens Replacement, Lens: Schritt 6, Bild 2 von 2
    • Unscrew and remove the gray backing behind the LCD screen.
  7. Sony Cyber-Shot DSC-H1 Lens Replacement: Schritt 7, Bild 1 von 3 Sony Cyber-Shot DSC-H1 Lens Replacement: Schritt 7, Bild 2 von 3 Sony Cyber-Shot DSC-H1 Lens Replacement: Schritt 7, Bild 3 von 3
    • Using a Phillips #0 screwdriver, unscrew the four 4.24 mm black screws off the blue panel on the right side.
    • Disconnect the white conductive tape.
    • Remove the blue panel.
    • Use tweezers to remove the three conductive tape strips on the right side.
  8. Sony Cyber-Shot DSC-H1 Lens Replacement: Schritt 8, Bild 1 von 2 Sony Cyber-Shot DSC-H1 Lens Replacement: Schritt 8, Bild 2 von 2
    • Use tweezers to remove the orange conductive tape located below the shutter.
    • Unplug the three ZIF connectors from the motherboard.
  9. Sony Cyber-Shot DSC-H1 Lens Replacement: Schritt 9, Bild 1 von 1
    • Flip up the blue overlapping board at the top.
    • Use tweezers to disconnect the remaining connectors.
  10. Sony Cyber-Shot DSC-H1 Lens Replacement: Schritt 10, Bild 1 von 1
    • Remove the motherboard and battery pack unit.
  11. Sony Cyber-Shot DSC-H1 Lens Replacement: Schritt 11, Bild 1 von 3 Sony Cyber-Shot DSC-H1 Lens Replacement: Schritt 11, Bild 2 von 3 Sony Cyber-Shot DSC-H1 Lens Replacement: Schritt 11, Bild 3 von 3
    • Use a screwdriver to remove 5 screws on plastic panel.
    • Remove the single screw on the silver panel in the center.
  12. Sony Cyber-Shot DSC-H1 Lens Replacement: Schritt 12, Bild 1 von 3 Sony Cyber-Shot DSC-H1 Lens Replacement: Schritt 12, Bild 2 von 3 Sony Cyber-Shot DSC-H1 Lens Replacement: Schritt 12, Bild 3 von 3
    • Use tweezers to remove the blue control panel.
    • Remove the lens from the camera.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Baylor, Team S5-G4, Williams Spring 2018 Mitglied von Baylor, Team S5-G4, Williams Spring 2018
BU-WILLIAMS-S18S5G4
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 13
Letzte 30 Tage: 24
Insgesamt: 1,582
