Zum Hauptinhalt wechseln
Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement
Was du brauchst
  1. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement, Battery: Schritt 1, Bild 1 von 2 Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement, Battery: Schritt 1, Bild 2 von 2
    • Using your finger, slide the release catch to unlock the battery/memory card cover.
  2. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: Schritt 2, Bild 1 von 2 Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: Schritt 2, Bild 2 von 2
    • Open the battery/memory card door.
  3. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: Schritt 3, Bild 1 von 2 Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: Schritt 3, Bild 2 von 2
    • Push the battery eject lever to free the battery.
  4. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery from the device.
  5. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement, Battery/Memory Card Door Seal: Schritt 5, Bild 1 von 1
    • Using a Phillips #00 screwdriver, remove the two 2mm screws on the battery/memory card cover seal.
  6. Sony Cyber-Shot DSC-TX30 Battery Cover Seal Replacement: Schritt 6, Bild 1 von 1
    • Using your fingers, remove the battery/memory card door seal.
Abschluss
3 Kommentare
hi sir do you have battery lock for replacement ?
John Anthony Geronez - Antwort
the Cyber shot by Sony has a lousy battery door it breaks very easily it's made of cheap plastic do you have any replacements for it?
SHELIAH HIPPS - Antwort
Where can I get the door catch - is it still available?
sid123 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 17
Letzte 30 Tage: 34
Insgesamt: 1,669
