Einleitung
If the movie button gets stuck or comes loose, it must be replaced to ensure that the device works properly and that the device is capable of maintaining an air-tight seal when used underwater to prevent water damage.
Was du brauchst
Using your finger, slide the release catch to unlock the battery/memory card cover.
Using a Phillips #00 screwdriver, remove one black 2 2/5mm screw that is located next to the wrist band loop.
Using the plastic opening tool, separate the edge-casing from the rest of the camera.
Using a Phillips #00 screwdriver, remove one silver 3mm screw located on the front side of the camera.
Using a Phillips #00 screwdriver, remove one silver 5 2/5mm screw located on the front side of the camera
Using a Phillips #00 screwdriver, remove one black 2 1/2mm screw located on the front side of the camera.
Using a Phillips #00 screwdriver, remove one 2 1/2mm screw located near the wrist strap.
Using a Phillips #00 screwdriver remove one black 2 2/5mm screw near the tripod slot on the bottom of the casing.
Using a Phillips #00 screwdriver remove the two 2 2/5mm black screws from the side of the camera opposite of the wrist strap
Using the plastic opening tool, remove the back casing of the device.
Using the tweezers, remove the movie button from the back casing of the device.
