Einleitung
In this guide, the camera will be disassembled and the button board will be removed and replaced. In order to reach this part of the camera, you have to disassemble the back panel.
Was du brauchst
Remove the six 3.5mm Phillips #000 screws.
Rotate the lock away from the camera.
Remove the two plastic spacers between the front and the back panels.
Carefully remove the back panel.
Disconnect the no-fuss ribbon cable by gently pulling it out of the button board.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
