Einleitung
In order to reach the flashboard unit inside the device you have to first remove the front and back panel, the button board and the top cover of the device.
Was du brauchst
Remove the six 3.5mm Phillips #000 screws.
Rotate the lock away from the camera.
Remove the two plastic spacers between the front and the back panels.
Carefully remove the back panel.
Disconnect the no-fuss ribbon cable by gently pulling it out of the button board.
2 weitere Personen haben diese Anleitung absolviert.
